Roger Tomfohrde
What is the difference between a D 282 crank and a C 263 crank? There must be something because they have different part numbers. The IT manual lists the dimensions and they show the same dimensions for both. Case parts breakdown shows the same gear on the front and the same part numbers for the connecting rods but different bearing numbers, why? I am confused as what IH did to make them different. Is it in the thrust bearing? I know the serial number have a break for the flange diameter.Or is it just they made it heavier for the diesel. I have the diesel crank out and am salvaging the motor which was stuck and was wondering if it would fit in a gas tractor. I don't have a gas crank out to compare it to.
Thanks
Roger
Thanks
Roger
