IH 340 T/A shifter spring
PaulW_NJ
Can anyone tell me where the spring (part #23) connects? There is a small hole on the bottom tip of the shift lever (part #42) where one end connects, but I can't figure out where the other end of the spring connects.
I've had this tractor apart for years, bought a new spring for it, but can't figure out how to (finally) put it back together!
Thanks!
There is a small hole in the bottom inside of the bracket, #43, where the back end of the spring is anchored. Hard to see the small hole unless the bracket is off or you are lying on the floor. Good luck!
Thank you very much! I felt under there and sure enough found the hole you told me was there. I never saw it. Now getting the spring installed may be a challenge!
