PaulW_NJ
I had to use a 20 ton press and lots of heat, carefully to not break anything, to remove a long frozen clevis pin from the PTO linkage clevis on the 340U I'm restoring. What do you use to lubricate clevis pins? Grease, anti-seize, etc?
Guess I don't understand your terminology. What do you mean by "PTO linkage clevis" and "clevis pins"? Maybe a photo or two would help.
(quoted from post at 20:17:11 07/29/16) Guess I don't understand your terminology. What do you mean by "PTO linkage clevis" and "clevis pins"? Maybe a photo or two would help.
[/img]
clevis is item #14
