Adding a loader- more hydraulic fluid?
I would like to add a loader to my Int. 340 utility tractor. When it has been mounted, with a transmission driven hydraulic pump, how will the new cylinders get filled, and will I have to add fluid to the transmission as I go, or is there enough in it to add after the unit is operated? Is bleeding of each cylinder required?
Yes you will need more fluid. Will you need to add mor as you go well maybe depending on cylinder size etc etc. As for bleeding the system yes you will have to do that but it is as easy as making the cylinder extend and close a few time and the bleeding is done
Make sure the hydraulic reservoir is full be fore you install the loader, and then top it off after the cylinders are full.
