1950 cub pto
Buggy97
New User
Having a little trouble engaging the pto on my 1950 cub. I've tried changing rpm's,engaging and disengaging clutch,and rotating the pulley that drives the shaft to the cutter bar. The lever seems to push down fully but doesn't go back all the way every time. Any thoughts or suggestions?
The lever slides a splined sleeve onto a splined shaft, and if the spline valleys and teeth don't line up you need to ease the tractor forward just a little to get them to match
