Hello all;
It's time to work on the 504 governor, since it was making weird noises and then failed completely (can't adjust speed from very low idle).
I've got everything out of the way, removed the radiator assembly stuff completely since it has it's own issues.
When I unbolt the governor housing, is everything going to fall in my lap (or on the ground), or should it hang fairly well together? I think I already know that I have to NOT remove the pinion or I'll risk having timing issues. With any luck, I'll find an obviously broken something or other and life will be easy.
Any advice?
Thanks,
Jim
Any advice?
Thanks,
Jim
