1941 farmall B carb
RustyFarmall will have detail answers to your compatibility issue but I know the carb for a Farmall and International 240 has a different hand choke attachment then those on the earlier tractors with the 113 engines. The 240 uses a choke cable instead of a rod which is connected to the carb with a clamp while I believe the earlier ones have a choke rod with a 90 deg. bend and held in place with a cotter pin. I don't have any tractors with a 113 engine so have little actual knowledge of their carbs. Other then that Rusty will have what you are looking for if he sees your thread, Hal.
measure the mount where it fastens to the manifold the rest can be made to work. The manifolds are different but the carb mounts could be the same.
