[email protected]
New User
I recently had a problem with the distributor on my 1967 IHC Farmall 424 4cyl gas engine. The engine turned over but the roto button did not spin. I pulled the distributor out and replaced the shear pin on the gear, re-installed it and the roto button still does not spin. It does begin to move trying to start engine but it stops immediately. I have a book on the tractor but can not find the housing that the distributor goes into. I believe it is the rear of the timing case. has anyone else had this problem? Should I take out the distributor, remove the rear housing of the timing box? Is there anything special I should do before removing the rear of the timing box?
