Hi all;
I've got this thing together and it's running pretty well, it seems.
So, now to fix the leaks on the aux valves, which I mentioned a while ago.
Here is a photo of what I have. The hydraulic tubes are welded to the other side of the block at the left of the photo, and that block is bolted to a support bracket. Nothing is moveable. I can't remove the valve end cap, sleeve, and internal parts because of the way the tubing has been bent. I don't believe this is "original", but I can't find any photos of what original might have been. Perhaps all installations are farmerized?
At any rate, can someone tell me if these tubing configurations are standard? Can I get original tubes? Do I have to have someone weld me up a solution?
This is a lot of work just to get to some O rings!!!
