glennster
have a 240 utility that i use for brush hogging. i picked up a woods rm600 3 pt finish mower and was looking to use it on the 240u. i found the prongs available but there doesnt seem to be a top link bracket available, sooo the option is the one piece. how will that work onthe rm600? the woods uses check chains to set mower depth when you lower the 3 point, and the lower lift brackets pivot so the deck will "float" the top link bracket on the woods also has a pivot on it. will this set up work on a one piece adapter? the 240u is the large point fast hitch.
