B-275 Shop/Service Manual
Shylo
New User
Hey my step-dad and I are repairing a 1961 IH-B275. We are having some issues finding a drain for the hydraulics. I am looking for a PDF or some scans of the manual. Money is tight and I cannot afford to send away for one at this moment.
Any help would be much appreciated.
Hi, with reference to attached parts diagram:
1) Place a clean bucket on the right foot rest
2) Loosen clamps item #1
3) Slide flexible hose item #2 forward exposing the end of pipe item #3
4) Grasp pipe item #3 and rotate it until the open end drains into the bucket.
After oil is drained you can pull pipe item #3 and filter straight forward to remove the suction filter to clean it. BE CAREFULL to pull straight forward so you will not damage suction screen.
To re-install suction screen put some hydraulic oil on O-ring item #4.
Filler plug is item #8.
Hope this helps
JimB
HELP!
I have an International B125 which has up until now started fine and been a reliable runner.
I believe the fuel level got low before I topped up a couple of days ago and now the tractor will either not start at all or it runs for a very short time and then cuts out.
I did not get a manual with the tractor so I wondered if anyone on here had any advice. I'm thinking there may have been rust or dirt in the bottom of the fuel tank, which is now preventing diesel from flowing properly into the engine.
Many thanks in advance.
