Swd9 block bore.
The specs for a D335 are 4.400 X 4.650, the difference being 0.250. So if they retained the same thickness in the sleeve for the D350, the 4.500 bore plus 0.250, should give you an OD of 4.750. Do not take this as the gospel, just an educated guess, I had this info all wrote down, but can not find it when I need it.
I agree. The outside measurement for a sleeve for a D350 is 4.751, so the block bore would be 4.750. I took this from some notes that I have from a post by Justin Weber a few years ago (Weber Tractor Parts). Justin is a reliable source of information on the sleeve/engine block dimensions.
