Diesel injection pump
wfdmctx1
New User
I'm needing to know what is the difference between injection pumps my is 0460306164 and the one we are looking at possible buy is a 0460306214.
We had part our tractor and went back the next day all of the diesel had dump into the oil. Can't find one with our #.
To be sure of getting proper help, tell us what tractor year, model# and engine it has. Serial numbers are OK but the other info gets us to the goal faster. Jim
I'll see what I can find out. I've repaired pumps getting fuel into the oil on VA/VE pumps, so maybe yours could be repaired? There are replaceable drive shaft bushings now available that can be installed and reamed to size that Bosch did not have before. E-mail is open on Classic if you want to get in contact..
164 pump is for the 358, full load speed 2500, 70-71 CCs fuel delivery. 214 pump is for the 310, full load speed 2400, 60-61 CCs fuel delivery at full load. If there are no serious breakage problems I'll bet yours can be repaired..
(quoted from post at 18:25:00 07/13/16) I'm needing to know what is the difference between injection pumps my is 0460306164 and the one we are looking at possible buy is a 0460306214.
We had park our tractor and went back the next day all of the diesel had dump into the oil. Can't find one with our #.
Farmall IH Model H on the side of the engine stamp in is 3055 005 R3.
I don't know if this will help with engine size or not.
(quoted from post at 16:19:41 07/14/16)
This is the serial # I found on a plate that has been attached to the tractor. 2510132U010858. I didn't find any # around the clutch or transmission.
(quoted from post at 17:39:31 07/14/16) Do you know the model of the TRACTOR?
It is not an "H," unless it had the engine custom installed. If it did, please post pictures!
[/img]
