Super C radiator hose
jjjg02
New User
Does any one happen to have the diameter of the top and bottom radiator hoses on a 53' Super C? I need new ones and instead of waiting for them in the mail I would like to see if the local NAPA would have them?
You need to find a place that has the hose in straght pieces they cut to length not all parts stores have it in stock take your old off the top to see if you have the thermostat that takes a larger dia and the bottom will be a different dia.
Got new ones for my 200 at the local Napa. Had to buy both in 1 foot sections, got extra for next time.
Looked at the spares, numbered 613 (2") on bottom, 616 (2-3/8") on top, and 609 (1-1/2"?) on the carb.
Likely same size as super c.
It has the thermostat, Had to replace the water pump and the bottom hose is leaking a little bit now, it was kind of brittle but thought it would be ok guess not. Thanks for the sizes now I know where to start.
The info is in the parts list.
http://partstore.caseih.com/us/parts-search.html#epc::mr56592ar489199
What you mean they wont cut what you need so ya gots to buy a foot crazy whats happening to NAPA ordered a reg for a 1100501 delco gen they had to get it from another store when it came it was for a 1101423 sadle mt 82.00 took em three da. So i went to another supplier next day ship 37.00. If they dont have it in store theres shipping. Local ORIELLYS has hose by the inch Napa doesent even have it.
If you know the diameter, ask the parts guy to look at the "fuel filler inlet hoses". I've bought one before and cut it to the correct length for radiator hoses on a Farmall A. Worked fine.
