Jake super MD
My super MD jumps out of 5th gear it will not go to middle of shift pattern when it jumps out only enough to slip back in on the go without using the clutch it only happens when going up or down hills or
pulling flat ground it will stay in gear the shifter is in good shape,how long would it take to split tractor and replace the gear, bearings and put back together in a limited time frame. I have not removed
the cover plate yet, do to time,and don't want to see the horror that could follow. I have heard it could be spring and ball or the gear its self. Any input would be GREATLY appreciated Thank you Jake
