1955 300 Utility Transmission Oil
buick8
Hi, I got this tractor running for a friend; I need to change the oil in the trans-rear end as I think it got some water in it while sitting outside for 8 years.
What is the correct oil to buy for it?
Also, what is in the hydraulic system?
There is a grease Alemite on the side of the water pump: is regular grease OK for this?
Thanks!
Regular grease, just 3 pumps, or so if it has been neglected, then once a year 2 pumps max. All gear and Hydraulic oil is Hytran or equal (be sure it indicates compliance on container, don't listen to the sales affiliate) Jim
