Need a front Rim for Farmall
For my Farmall 706. It has an 856 wide front end under it. The tire size is 10.00 x 16. Where can I get a front rim? 6 lug. Any help - ideas are appreciated. Thank you.
That rim size is the common tractor/implement rim size so any good farm and home place or tractor dealer should have them or be able to get them. Your problem is you need a wider rim then say what is used on a ford tractor like the 801 series etc
That's a special offset on the 806 -856, you might have to get a used one, from a salvage yard and i believe that's a 8 bolt isn't it ?
There is no 'specific' "856 wide front". That same front was 'factory' 706 to 1256. It would fit from M to the 1256,even 1456.The 6 bolt hub and 8 bolt hub each use the same bearings.The spindle is the same for both,the 8 bolt being the 'heavy duty'. Rims are pretty standard. My 706 had 9.5L15 when I first bought it. It now has 10:00x16 on it. The 6 bolt wheels/rims came from a junk JD 6600 combine.
