Goose
Per prior threads, I had an input pilot bearing fail on an H. Besides replacing that bearing, I disassembled the entire trans and found several of the rest of the bearings worn enough to merit replacing.
Now I find the differential side bearings are also worn. After pulling the brakes, what comes next on getting at the diff bearings?
BTW, our local Case IH dealer so far has either had parts in stock or could order them with delivery in a couple of days. They even had the big gasket for the top cover in stock.
Thanks for any advice.
