OldFarmall450
Ok, I charged the battery and had it tested, (its good), picked up the starter ($175.00), and got new terminals for the starter connecting wires (the smaller ones) and went back to the farm. Installed the terminal ends, starter, battery. Wanted to see if it would turn over before more troubleshooting. Turned on fuel, choked it, hit starter button. It turned over twice and burst to life!! I actually did a little victory dance with my wife looking on shaking her head!
Climbed aboard and used 4th gear to leave the lot, then used 5th gear DD and started the 13 mile trip to the shop. About a mile into the trip I throttled her down to make a turn, and when I throttled her up she shuddered and acted like she had trash in the carb. It ran so rough and vibrated enough to make the throttle jump out of high, so I held it down for a cpl miles. It finally smoothed out and ran fine the rest of the trip. Wife said she ran a consistent 15 mph.
Got to the shop and doors were open so I drove her in and parked on the slab. I climbed down and saw black nasty oil dripping from the rear of the engine. I moved her to the gravel and idled her down again. I knew the oil was old and nasty and replacing it is on the agenda.
My mechanic came out and looked at the leak and said it looks like the rear main seal...but wont know until he gets it cleaned and can check it out.
SO.....if it IS the rear main seal what am I in for? How many ways are there to fix it? The leak looked to serious to be operating it, unless I stop every hour and put more oil in.
Thoughts, ideas, and suggestions are welcomed.
E.
E.
