KY AC
Value of a 560 diesel with a bad motor. Wide front fast hitch alternator conversion 2 remotes good rubber
If you would have someone make it "all better" it might take all of or more than 4000 to satisfy the bill. If a 5000$ tractor is in your future, and you need or want a 560, 1000 is reasonable. Jim
Went to a sale two weeks ago to maybe bring a 560D with a turbo on it, listed as a mechanic special. Did not start it due to water in oil. Good rubber, fast hitch, two valves and narrow front. Thing brought 1800.00, think a Mennonite bought it. They like to put in 400-450 ring and pinion gears, and larger tires to get the road speed up over thirty plus.
$500 plus the value of the tires, which probably puts you in the $1200-$1500 range.
If by "good" you mean the tires are matching and nearly new, that's worth $1000 by itself easy. It would cost you way more than that to replace them, and you can always use them on another tractor or sell them if this turns into a total bust.
Guy says he will take 500 for it. I have an engine ready to go in it. Tires are matching on rear. Knowing my luck though something will be wrong !!
