Back wheels on a Farmall B
fastfarmall
It's getting old, and the bolts i dont think have ever been off, I tried the 1/2 in air wrench, it didn't budge them, put the 3/4 drive on them, i could feel them twisting off !!! What do u recomend? The wheel weights are off !
If it is the bolts that hold the wheel to the hub, remember they go through the hub and you need to apply the penetrant from the hub side and also strike the heads with a heavy hammer before you try to loosen.
If it is the bolts that hold the rim to the wheel just let them twist off and replace them
I'd recommend lots of heat and penetrating oil. Get that bolt orange hot and then put the impact to it after letting it cool slightly. You don't want to shear it off while it's red, but do it before it completely cools off. Goodluck!
