C with C135 engine?!
I recently bought a C not a super C, something got down the stack, thru a valve and cracked a piston. Now i got the head off and discovered the pistons are 3-1/4". The casting # starts with c135.. i am assuming someone reaplaced the smaller motor with a 135, that said can anyone tell me what the differences in the engine/ engine specs are and what may i run into when hunting for a piston? Thanks gents!
First the later blocks could take a thinner wall sleeve thus 3 1/4 they look the same as a 113 when looking. Then later blocks with different gov housings and some other changes hard to tell just what you have. Howard Enterprises can get you the parts or Abeline Tractor.
