IH tool FES 10-27 countershaft removal---what is it?
I need to replace gears in my Farmall 656 transmission. The book says to use "FES 10-27 tool or equivalent" to drive the countershaft rearward and remove the rear bearing cup. I can't seem to find any info on this tool, what it looks like or where to get it. Can anyone advise on what it is, and perhaps a picture? Where I can get it? Is there a substitute I can use? Thanks for any info!
(quoted from post at 21:29:28 06/23/16) I need to replace gears in my Farmall 656 transmission. The book says to use "FES 10-27 tool or equivalent" to drive the countershaft rearward and remove the rear bearing cup. I can't seem to find any info on this tool, what it looks like or where to get it. Can anyone advise on what it is, and perhaps a picture? Where I can get it? Is there a substitute I can use? Thanks for any info!
This is from the 560 transmission service manual GSS1340, should be similar on your 656. It appears the tool is part of a bearing and bushing driver set.
[/URL][/img]
Thanks for the info. It appears that it's like a bushing driver, designed to move the countershaft rearward without marring the front face of the shaft. I think I may
have a substitute that will do the same thing. Will have to see once I get the transmission apart. But thanks for the picture it helps.
That tool was part of the tool kit that the dealers bought when the tractors were new , they were made by O T C and as a individual you can not buy one . The only way to buy one is with a letter head from a current Case I h dealer or be lucky enough to have bought out a closing I H dealers shop as i did and get the special tools . They do make life soooooooooo much easier when working on tractors .
