706 Hydraulic question
jg_cr22
New User
I have a Farmall 706 diesel and was only getting about 400-500 psi measured at the rear. Replaced hydraulic pump and now get 1000 psi at the rear. It takes tractor a lot of throttle about 1/2 before it begins to lift. I read on here that I should getting near 1600psi, any thoughts?
Well first off pull the three point top link plate and look over to the right side looking up and run the tractor and see if there is a LOT of oil coming down. Then get back with me
(quoted from post at 09:28:11 06/23/16) Well first off pull the three point top link plate and look over to the right side looking up and run the tractor and see if there is a LOT of oil coming down. Then get back with me
I'm sorry for the late response. It is a pain getting a consistent internet signal out where we live via satellite internet. I have attached a link where I have posted a video showing how much oil is coming down (seems like a lot of oil). There will also be one picture looking at the top left corner. There is a silver small pipe? It leaks every so often, and I noticed a squirt or leak of some sort. I hope you can view it in the picture.
https://www.dropbox.com/sh/3a01h5oharmv423/AAD1bCW_ElDSTpC8kDq-JJcoa?dl=0
Sorry I had not checked in recently. My father had a heart attack and was preoccupied. Still having same issues as before. The Dropbox link shows more details.
