Assuming a general description will do. The BN is a tractor with a 113cid 4 cylinder engine. It is a variant of the Farmall B it is about 8 inches narrower than a B through the use of shorter equal length rear axle housing/drop boxes. The reason for its design includes (my opinion) the apparent width of the B series being a bit difficult to put in a building. The need to accommodate different row widths and spacing with a limited adjustability type of wheel mounting. The use of mounted cultivation and tillage tools was featured with a hand lift system, or a exhaust pressure lift device. They are 15 to 22 horsepower (modifications and tuneup based). The PTO is transmission driven, not live. there is no hydraulic system. They are powerful for their weight, and nimble tractors. Jim
It was made fro veggie crops and with the veggie cult could do up to 6rows 15 on center rear wheel tread was very adjustable for row width in 4in at a time spacing you need to do the math for row spacing. They had rear planting units also with adjustable row widths and the clearence on tractor height made a fine unit for the veggie crops.
