H Farmall with Schwartz wide front - I noticed that the steering was getting a little looser on the H. The Schwartz wide front has an adapter plate that connects the upper bolster to the inner tie rod ends (adapter replaces the lower bolster). The bolts that hold that adapter plate to the upper bolster shaft are loose.
How do you get in there to tighten them ? Does the upper bolster have to come down ? Does the front end have to come off ? Any ideas ?
Thanks
Greg
Thanks
Greg
