Hello Gentlemen, I have a row crop 300 which is a good old tractor, I have never had any problems ever with the PTO until the other day when I engaged the PTO and nothing, it worked perfect the last time I used it, no noise nothing,
I see on the right side above the PTO shaft is a about a 2" long x 1" wide cover held in by 1 screw. I removed the cover and found 2 slotted bolts with a nut on each one? What does this adjust and could this be something I need to adjust?
Need to get this fixed so I can start cutting some hay, when it stops raining.
All help would be greatly appreciated.
Thanks In Advance.
Jay
Thanks In Advance.
Jay
