farmall 200 crankshaft and rod journals
dewy
in I&T manual says crank journal is 2.1245 diameter, what is the rod journal diameter..all i could find were running clearances...also
what does runnin clearances mean.....i have two cranks trying to figure out which bearings go to which crank...one set is standard the
other is .020.....thanks for input in advance..........dewy
the .020 brgs. will be thicker due to the crank being undersize. the .020 brgs. should be stamped as such also. dont know if you have calipers or inside mic to measure them. but another thing without tools can just try each one on a journal and see which one fits. you need at least .0015 brg clearance. the brgs that dont butt up to each other on the original crank are the .020 undersize ones.
and to measure them put them in the rod and torque it to spec and then measure the brg diameter. do the same for both and you have your answer. thats if the rods are out of engine. the smaller diameter is the .020 brg.
found diameter of rod journal on this web site where u order bearings,,,1.75 ......also found stamp on crank .020.......thanks again..dewy
