International 37 baler shear pin bushing
burnsg2004
New User
I have a international 37 baler same as a 47 baler. The flywheel has a bushing that threads into the flywheel that the shear pin slides through . Wen baling the other day I guess it worked loose and fell out. I called international and they say they do not list parts for that baler. any body have an idea where to get the part or some other alternative any suggestions or help is appreciated. The baler is old but does a good job baling.
The bushing doesn't actually "thread" into the flywheel, does it? It just slides in. As I recall the 430 baler is similar, and may actually be the same part, which would also mean the 435/445 balers are the same.
If it's just a straight bushing, anyone with a lathe could make you one.
Very odd you didn't find it laying on the ground in the field when the shear pin broke, or didn't keep looking until you found it.
Hardware stores, Tractor Supply, and the "blue" box store all have hardware drawers with steel bushings in them. You can probably find a bushing or combination of bushings that stack together. Odds are the hole in the flywheel is a standard size.
What kind of IDIOT "International" person did you talk to?
The parts catalog is even available on the consumer website!
Part # is 662122R1, still available at some $40.
(Replaces 202987C91, 662460R1.)
Apparently, it IS threaded 3/4"-16, is 1/2" long and has a hex head.
Look under: (00)-Complete Machine (B19)-Main Drive
Parts catalog
