Rex Simpkins
Brought home the Farmall 544 yesterday, everything is fine except the shut off cable-- ordered new one 403868R2 ended up same as the one thats on it--not right. this tractor is below 14000. The new style cable from Case
will not secure to the dash it just lays in the hole and when you pull it whole cable pull
I need the correct cable because the injection pump has three positions in+run, halfway=start, out=stop
