Steering parts for Farmall Super H
vjwheeler
New User
Need steering worn geer and other related parts for a Farmall Super H. Are there any other models such as a Farmall M, H, 350, that would work? :? Thanks.
(quoted from post at 19:00:42 06/12/16) Need steering worn geer and other related parts for a Farmall Super H. Are there any other models such as a Farmall M, H, 350, that would work? :? Thanks.
here are you?i have good steering shaft with worm gear for h im at garrison iowa
Look at Farmall IH parts for a SH on this site in steering. Will be new aftermarket parts tell you what tractors the parts can be used on. Bushings are mostly a dealer item, can find some bushings from other places but may need resized before or after installing. If tractor has a full circle gear on the splined shaft and it was never repositioned it can be moved on the splines to get unworn contact straight ahead and just get into a worn area at full turn.
