notjustair
I've tried searching the internet but don't seem to find anything about this.
The rear remotes on the 886 bleed off. Enough that when I pull the bat wing mower I have to keep bumping the height up - it bleeds off fairly quick. If left to its own devices it would drop an implement completely in about 6 hours.
I assume seals need replacing. Are those within the remote valves behind the right battery? The loader is plumbed with a power beyond plate and it stays in the exact same spot indefinately.
