Ok,
So got that Farmall M that ran when parked about 18 months ago.
I drained about 3 quarts of oil out of it. Filled it with 8 quarts of SAE 5w 30.
Poured in 2 gallons of 50/50 anti freeze.
Installed a new oil filter and gasket.
Flushed fuel tank, installed new sediment bowl screen and gasket.
removed carburetor and split it open and cleaned it all out, cleaned the inline filter inlet.
Flushed fuel line.
Installed new starter switch.
Bought new spark plugs and gapped them.
Last obvious thing it needs is valve cover gasket. Will order one and install it this week.
This week am getting some welding cable cut for the 6 volt battery. Will cut to lengths and install.
What 6 Volt battery do you guys recommend?
Outside of that, is there any other things to pay attention to prior to giving it a first cranking over?
Flushed fuel line.
