M sediment bowl
I use one turn of small-diameter Teflon valve stem packing, around the stem, just under the nut.
I've found the string on a feed bag works well, wrapped tightly around the threads. It's amazing the uses for that string...I keep several in the truck, deer stand, hanging in the barn...
Good luck
Before you spend too much time and energy, go price a whole new assembly from Case-IH. Not too many years ago they were priced low enough to make it a no brainer. Might not be that way today.
