Super C Draft Link/Fast Hitch
Evening Folks,
When I bought my Super-C from TractorSam, he warned me that before I wanted to do any plowing, I'd need to fix the two components of the Super-C's Fast Hitch Draft Link. Well, after doing a bit of damage to the hitch horseshoe that required the use of the blue wrench, Sam straightened up the lower half of the draft link (part 4 in the following diagram)...he had jury-rigged a link to work so he could plow his garden before selling me the tractor, but I would rather like to get the proper device in there, even if it hardly sees use.
So, here's the diagram from Case/IH:
Case-IH Hitch Diagram
What Sam fixed is #4, what I need info on is #1, the rod that goes from the lower link to the upper rockshaft. I understand its a rod with a series of holes. If someone could provide a picture, as well as the spacing of the holes, distance from the top, diameter of the holes, length of the rod, etc, it would be VERY much appreciated.
Thanks in advance, everyone!
Andrew Reid
Thanks Larry, Don't suppose you managed to get that picture today? Im in no huge rush, Im just considering a trip to the metal supplier either tomorrow or Wednesday, and thought I'd pick up what I needed then.
Cheers!
AR
Your link will not open on my end.
I have some hitch parts from a C or Super C. I think this as the front hitch has some parts that are round solid bars, and my 100 & 200 use solid square bars instead.
Since your link wouldn't open, I'm guessing the part is either the adjustable link that attaches either to a pin on the side of the torque tube, or attaches to a Touch Control Arm ? I've got an extra
If you are going to make one, I would bevel the front-top corner, as the square corner will rub the lower hydraulic line if I am not careful.
:( Andrew
Sorry I took so long getting these pictures posted. I had boom sprayer rebuild problems then the vgreat grand kids come out for a couple days.
I did finely finish up with the boom sprayer about 1000 PM last night.
(quoted from post at 22:42:13 06/17/09) :( Andrew
Sorry to bring up such an old post but I am in need of one of these draft links. From seeing these pictures, I think I have to lower part because its bolted to the tractor. There is one on both sides bolted to the tractor with the other one looking homemade
You should only have one of those links, on the right side.
There is a different kind of link on the left side, made from flat bar, that runs tight along the side of the tractor, over the top of the left axle housing, to the hitch. This controls the side-tilt of the hitch for plowing.
