560d injectiors
560farmer
Before I have a a mechanic look at it I wanted to try one more time at it so I unhooked all my injectior lines and cranked no fuel came out and I got to looking and there was fuel puddled up in injectior except for the 4 injectior any help would be helpful.
then you have pump problems if lines are off and with cranking no fuel comes out. did you try to pull start it? because before you said it was smoking.
(quoted from post at 14:11:59 05/26/16) then you have pump problems if lines are off and with cranking no fuel comes out. did you try to pull start it? because before you said it was smoking.
t smokes with lines off
No need to jerk it because if you do not have every thing fuel glow plugs, it will not start any way. Could be the delivery valve, if so you could drag it around the world, still not start.
yes, i know that. but he was saying cranking slow and smoking... so remove all doubt and pull it 10ft and it will start. i agree on delivery valve and what u say but at least try the drag and eliminate other problems. its like he has been trying to start this thing for months now. i know a few times when i was young battery's were not up to snuff and dad just pulled the 560 with 1/2 ton less than 10 ft and it was running. gotta do what u gotta do at times.
(quoted from post at 17:30:06 05/26/16) yes, i know that. but he was saying cranking slow and smoking... so remove all doubt and pull it 10ft and it will start. i agree on delivery valve and what u say but at least try the drag and eliminate other problems. its like he has been trying to start this thing for months now. i know a few times when i was young battery's were not up to snuff and dad just pulled the 560 with 1/2 ton less than 10 ft and it was running. gotta do what u gotta do at times.
es I'm young just goin into high school sorry for the trouble and Yes I have pulled it behind a tractor over 300 yds
If you have fuel at the filters and at the connection
fitting to the injection pump and no fuel coming from
injector lines there are two possibilities. Either the
shutoff lever is back or the pump is bad. PERIOD
