Glen wentzell
This past few months ,when letting tractor sit for long periods of time not in use,the hydraulics wont work after startup .After some "fiddling" and sitting with the tractor running they started working and would work good ,till you shut it down,and then the next time when used the same thing will happen.not always ,,but sometimes.
Today it happened,and the hydraulics wont go up,or down.I have no 3PH movement ,no front end loader movement .I checked the fluid and its full.Would it be air,,or the pump going bad?
Or would the clutch need adjustment.
It,, 'the pump hydraulics" seemed to make a funny "whirring" noise depending which way the levers to the 3PH was set to...
also,i turned the adjustment valves under the seat but that made no difference.
Which way do i turn the adj under the seat? There is only open,and closed,and fast and slow.
Thank you.
Thank you.
