Trying to track down the water in my oil pan. I had the same problem 6 or so years ago, replaced the head gasket and it seemed to fix it until about 2 years ago when it started steaming out the breather and the coolant was back in the oil.
I pulled the pan to see if I could see anything weeping around the sleeve, I gave it 3 or 4 days and I can’t see anything. I tried to put a little pressure on the system, I couldn’t get things to seal real well but it didn’t help flush anything out.
I just pulled the head, other then a puddle of of oil and antifreeze on the deck by cylinder #4 (which I don’t know if happed when I pulled the head or if was there all along). Visually the deck looks great, the same with the head.
Not sure what I should do. Replace the O-Rings just in case of slap a new head gasket in and see what happens. Any other ideas?
K
K
