Super C Hydo Resivoir Breather Cap
Now, the neighbor had a SC with a loader, & it
had a 1 1/2 gallon reservoir tank mounted on the
right light bar. It had a cap similar to ones on
the starter tank on MD & 450D tractors--only it
had a brass waste thing for a breather.
Whether this tank was IH or some other outfit
maybe made them, this might be what needs to be
found.
The neighbor got all of his parts & stuff from the
local IH dealer, & had the service men do all of
his work, so there is a good chance IH did put out
the reservoir as an add-on kit.
Thanks for the information. There are external threads on the pipe. I'm pretty sure all I need is a cap.
If you are talking about the filler on the side of the Touch-Control block, there shouldn't be a pipe, just a pipe plug that screws directly into the block.
