bassmasta76
I should know better than to assume anything, but is it safe to assume that there should be very little to no end play on the transmission driving shaft? I've got the tractor split, and the belt pulley unit removed.
If I stand right in front of the tractor and look down into the rectangular hole where the belt pulley mounts, I can see the gears, etc. If I push or pull on the driving shaft coupler, there is quite a bit of play, maybe as much as 3/16". If I pull on the coupler, the larger gear appears to rub the bearing case, though I'm not sure as I've not pulled the unit from the tractor.
I know I need to take things apart further to get a better idea of what's going on, but would assume that it's worn bearings?
thanks as always!
--b
thanks as always!
--b
