farmall h: worn lifters fix?
R&W
im overhauling my farmall h and te faces of the lifter is worn, where the lifter rides on the cam. my question is, can the lifters be machined back to be flat?
They are not flat when new. If the lifters are worn out, then so is the camshaft.
Berry Cam in Lester Prairie MN will reface your lifters for a few bucks each. But as noted below, you
probably need the cam reground. Berry does that too. I had a Super H grind put on mine and it helped a
lot.
Greg
the cam followers are machined to convex shape, so the cam makes them rotate in their bore. and once the followers are worn like that then the cam needs grinding or replacing. once they are flat or concaved they are junk. i had mine resufaced on my wk40.
