IH2444/ C153
lcreasy
New User
I am parting out a IH 2444 with the C153 motor. Please let me know if you are interested in anything. I live in Illinois. Thanks.
(quoted from post at 12:19:54 05/19/16) I am parting out a IH 2444 with the C153 motor. Please let me know if you are interested in anything. I live in Illinois. Thanks.
Hi been looking for both hood skirts and the sheet metal wrap
Under the dash.
also looking for the spacer on the lowering spool valve spring.
Even if it only dimensions of the spacer...ill make one
Thanks
Are you referring to the sway limiting chains or height limiting check chains for a mower for example?
I believe I have the hood skirts if we are talking the same part. Don't have any sheet metal under the dash. Please provide more detail on the spacer part. Is it for the 3 pt or the loader spool?
(quoted from post at 05:26:30 05/20/16) I believe I have the hood skirts if we are talking the same part. Don't have any sheet metal under the dash. Please provide more detail on the spacer part. Is it for the 3 pt or the loader spool?
The hood skirts run under the sides of main hood that muffler and air cleaner shoot thru....they are somewhat tapered front to back,
They attach to the bottom sides of hood...
..also need the complete front Headlight assembly insert
The spacer in question is for the 3 point... The head plate (main plate the fluid pumps into would need to come off to see it )
Guessing...it's approx 3/8-1/2" long.....adds more pressure to spring, if your willing to take that area loose..
Thanks
Remembered another part I need.....is the tach drive gear in
The distributer housing...need to remove tach cable from
Distributer and its in the assembly that would come out of housing
Thanks
I have the sway limiting chains. Send me an email with your contact info and I will send you some pictures to confirm these are what you want. Thanks
I should have all of those parts. Send me an email with your contact info and I will send you pictures to confirm those are the parts you are looking for. Thanks
Hi,
My email is : [email protected]
I'm listing the parts here again plus a couple more,
When you send the pictures back let me know how much $
For each or for all, and shipping,
Thanks
Darwin
Hood skirt panel right hand side
Hood skirt panel....left hand side
Headlight panel assembly
Tachometer drive gear
Air cleaner top cap
Brake lock lever
Lowering spool spring spacer, this part is shown in the
I.H. Service manual but is shown incorrectly in the
I.h. parts book and wrong online as well.
Some disassembly of the hydraulic unit under the seat
Is needed to find it. If hydraulic unit is hoisted up just
Enough to separate the outer head block.
Don't need to totally Remove it. There should be a spacer
on the lowering Spool spring which fits into the head portion
that Would be partially removed at this point. Understand if
You don't want to rip into that.
Might be more parts,I'll see what's in the pictures you send
Thanks
(reply to post at 12:19:54 05/19/16)
ello. I know this is a long shot since your post is so old, but wondering if you still have the 2444. If so, do you still have the front axle? Thanks!
