28plymouthman
New User
New coil and ballast resistor. Took off all wiring and cut ends for new coil and didn't write down where they went. Could some one tell me where on the ballast resistor the hot wire from the key goes or does it go on the coil + side. Then there are two white wires connected together with two ends to be connected in two different areas. I think they are coming from starter solenoid. Would one be on the coil and the other end on the ballast. I do have a 12v reading on the red wire when switch is on. The new coil has a new wire from one end of the ballast to the + side of the coil. I did connect a wire from - side of coil to distributor. Is this right. Or does the wire from the distributor go to the ballast on opposite side of the wire already there from the coil. Thanks in advance, what a mixup.
