M questions
Which way is up on the oil filter for an m? The tractor did not have the correct oil filter on it so I don't have a reference.
Also when adjusting the valves the service manual has the specs for adjusting them hot but is there an adjustment for cold?
There is no specification for adjusting them cold. After rebuilding an engine, I set the valve lash to .019" with the engine cold and once I get the engine running, I reset them to .017" when the engine is hot.
