New 560 Diesel Turbo kits
A good friend of mine used my M&W turbo and manifolds off of my 560 to build a jig to make manifolds for D282. We are going to build more and for others also. Will exit factory exhaust hole. Uses a T04 turbo and 3.5" stainless tube and plates for this application.
probably around $2500 haven't sorted that out yet. It would include correct turbo and filter if needed for each application.
got a picture of one installed? where were you going to mount the air cleaner? i assume your not going to use the stock oil bath?
(quoted from post at 19:59:13 02/16/13) can run either oil or dry, going to figure out which dry can we can use. So it still looks factory.
Aren't oil bath filters sized acording to air flow to the motor? Therefore with a turbo you are going to suck all the oil out of your mesh.
(quoted from post at 20:04:40 02/16/13)
i assumed the same thing, but i recently got a 560 with the IH TD-9 turbo setup on it and it still had an oil bath. i was told that a 660 oil bath will work a little better since they turned 600rpm's more that the 560's did
wont be a rayjay turbo. Try to buy one from someone else for that price. I know this board is not the classified ads. Was just posting because I can and someone asked how much !
(quoted from post at 17:58:57 02/16/13) A good friend of mine used my M&W turbo and manifolds off of my 560 to build a jig to make manifolds for D282. We are going to build more and for others also. Will exit factory exhaust hole. Uses a T04 turbo and 3.5" stainless tube and plates for this application.
WOULD LIKE TO ORDER ONE FOR 1962 560 DIESEL
