Hi
I removed the pump on my 240 to look inside and determine if a seal kit would work or if I need to replace it .The surface of the area where the gears turn look scored or could be rough machining . Should the surface be smooth ? Also , being new to this tractor , I can't find a brand name on the pump . There are numbers .653K and 368633-R91 . I need to know if I need a seal kit or new pump and what and where to find what I need .
Thank you for your help in this matter .
MIchael
MIchael
