Worked on the tractor in the rain today, put starter off of other tractor on and with 12 v battery it started on gas and switched to diesel.
Temperature was high 40's and raining and it switched over smoothly and never smoked or missed. TA will kill the engine in fifth gear full
throttle so overall I think it is a real solid tractor. Throttle control looks homemade, definitely different than my other SMTAD or MD's would
appreciate thought on it, serial number is 759xx, forgot to write it down. I am thinking that brackets on the front were for cultivator mounts?
Also has mount under center section that looks like the belly pump bottom, is that implement mount also? Thanks, Mike.
