H Farmall picture
DTK
Hi, I finally got around to post a pic. of the H and 33-A loader we tuned up last summer. Sorry, I shook a little when I took the picture. Thanks DTK
If you are posting from a mobile device such as an ipad or iphone you will need to manually rotate the picture to the desired position on a computer and save it before it will post upright on the forum.
Nice looking setup though!
Nice set up. My Dad had one of those loaders on his H. He had to add a starter and electrical system at the time as it was only hand crank.I would love to find one of those models around here but have never seen one locally for sale.
down load. use windows viewer to open, (or other bitmap viewer) rotate with commands at bottom. Post. Jim
I have the same tractor and loader. It's a very handy setup. I leave the snow bucket on most of the time for moving stuff. I installed quick connects and made stands. I can remove it in 5 minutes. Putting it on takes about 15 minutes.
I've only seen 3 so far, yours, mine, and one at a salvage yard.
I can also adjust the lowering speed.
I have an H with a 33A loader on it. Several years ago, I went to a CIH dealer to get leathers for the lift cylinders, and some young squirt on the counter swore up and down an H could not have a hydraulic tilt loader on it.
About the time I told him I'd go get a picture of it, an old timer came over, poked through some microfiches and came up with the leathers.
