Over the winter had our 230 apart fixing a few odds and ends, painted it and am now in the home stretch. Currently having issue with it charging. I have replaced the wiring on the tractor as it was pieced together, the regulator is new and generator was checked out locally and was said to be good. Start the tractor shows a slight charge. Turn lights on shows discharge. Lights off I can unhook the negative cable and it will stay running so its obviously charging. My guess is the generator is putting out a charge but not high enough for the lights as well or do I potentially have something wired wrong? Thanks in advance
