Farmall 60 series hyd. pumps the same?
Al L. in Wisc.
Peeking at the IH online parts site, me thinks the Cessna and Thompson hydraulic 17 gpm pumps used on Farmall 460 and 560 tractors are interchangeable, correct? Answer is for a comrade at work; his new-to-him 560 pump won't hardly, thus he is in need of a good one. Thanks in advance.
No they are not completely interchangeable. The Cessna has a deeper cut cover. I was changing the cover and found the one for the Thompson is machined different and it would not seal the plate. It bolted to
the plate fine but the Cessna plate is carved out deeper and the plate for the Thompson had a gap. Now I have a plate for a Thompson I need to find a home.
Hope this answers your question. BTW the number on the cover cross references well.
Hope this helps.
Roger
